Direct Drives and slide-ins have the same basic component , pumps, blowers, drive system and hoses.
The diferences are in the drive system and the additional engine on the slide in
The difference is the lawn mower engine in the slide-in is working it's ass off and blasting 300 degree heat at the blower and pump and belts and hoses for hours on end.
A 25hp Kohler takes 2 qts oil every 100 hoursA 5.7l chevy takes 5-6 qts every 3k miles in pto mode (1700 rpm=35mph) thats every 85 hours = 3k miles.
edge Slide-in
I change the oil once a month on my Express you have to change every 3 months plus monthly oil changes on the lawn mower engine. Edge DD.
Drive system,
Slide in belt drive or coupler once a year takes 30 minutes, cost 25 bucks
Direct drive Clutch Drive and/or belt on PTO 2-4 hours to replace every 2-3 years 25-50 if just belt 350-450 if Clutch, If shaft or bearings need replaced bend over.
Edge Slide in
I had them change my blower belts at 7000 hours (after 6 years) and they charged me for 1/2 hour labor. (They didn't need changing.) Ive heard slide-in owners brag how they can change their blower belts in 45 minutes because they have to do so every 100 !!! hours. Edge DD
Engine replacement
Slide in 1500-2000, takes 30 minutes to do
5.7 Chevy 3500-4500 truck down atleast 2 days.
Edge slide-in
It will be another ten years before I change the Express engine which is eight now with 80000 hours. Slide-ins are routinely change at about 4 or 5 years. Edge DDThere are many more examples, like issues with the Vans cooling system. Vans cooling systems are simply not designed to run 1700 rpm standing in place hours apon hour with the only air passing the radiator is from the fan.
The engine of the van in a DD is cooled by the water used. And when a slide in brakes down you can still drive it to the parts store to fix it, Direct drive will require a tow.
A DD doesn't normally "break down".
Wreck a van with a slide in, much easier to move into a new van.
Still have to unbolt it and get a hoist and put a fuel tap in a the new vanNot to mention most Direct drives under perform compared to most slide-ins, turning the blower slower and at lower lift to compensate for a weaker drive system (clutch). Run that blower @ 3400 rpm and 15hG and watch that direct drive shaft/clutch/belt shread.
My Pro1200 blower turns at about 3000 RPM when the van engine is at 1500 RPM. The Roots 56 is adjusted to 15 1/2-16 hg. I don't care about other DDs; they may underperform.
