Carpet Cleaning Fool
- Joined
- Nov 9, 2008
- Messages
- 1,496
- Name
- George Valliant
Harbor Freight heat gun $14.00. Also, it works good at warming-up numb fingertips.
Saiger" data-source="post: 4257417" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I don't touch them unless I have asked permission from the homeowner (any time of year) and then we immediately check the inside of the home to make sure they are not broken and leaking. Keep in mind, it is only when you have back pressure on your hose of the bib, that the water is going to start spraying back into the home.
Today, we are just making a plan to add water to our tanks in between the first and 2nd job. That should make us through the remainder of the day with the jobs we have.
That, Mark, is why I'm looking into adding water tanks, or buying a unit already set up with tanks. I'm tired of looking for a safe water supply, especially in this friggin' cold! I just missed out on a beautiful used setup, with low hours, average miles, and a crap load of storage space. Big waste tank, freshy tank, APO, elec hose reel. Friggin' banks are just too slow to respond, especially if you haven't used credit in 10 years. I'll be ready for the next deal.
I'm hooking up more and more inside the house and running lukewarm water out to the van. It's just too dam cold, even if I can get the spigot unfroze, it's just going to freeze again.
You spent all this money on your truck mount to make you more efficient then the portable guys and then waist half your time savings running around looking for a water hook up or being worried about lines freezing in the winter.
I don't know how you guys do it without onboard water. You spent all this money on your truck mount to make you more efficient then the portable guys and then waist half your time savings running around looking for a water hook up or being worried about lines freezing in the winter.
I froze my Vac hoses together today and I couldn't get them apart. My filter basket for the vac was coated with ice and the inlet to my water tank froze over and shut down the vacuum. Ain't wither fun!!!
That's the exact heat gun I used yesterday to get my flag pole unstuck.We put Christmas lights on it to look like a Christmas tree for the lighting contest. Between the heat gun and hot water we got it up just moments before the judging.
