Goomer
What thermostat settings would be best to recommended to any retail/office clients after a HWE cleaning when the location must be secured immediately following the cleaning, where no windows can be left open, and the HVAC system will be the only source of ventilation?
I usually recommend the "ON" fan setting, as opposed to "AUTO", to keep things moving.
Do you suggest that the thermostat be set a little warmer than normal to speed drying, or should room temp be adequate??
