rstrick said:
			Educated responses only please!
I dont know exactly but would like to know the difference between the two.  Is the dry method the same as encap?
Thanks.  Really looking in the area of residential cleaning.
I have been asked by customers and would like to respond with some knowledge based answer.
Thanks
Ryan,
As an ex-Chem-Dry hack i'd be happy to answer your question.  Most CD's (as stated earlier) are still using the bonnet method.  This is NOT a deep clean, recommended as a maintenance clean (light-medium soiled carpets).  You pre-vac, spray carpet with a chemical CD calls the "NATURAL".  It has a neutral pH and is carbonated.  The selling point is that it's non-toxic and low-moisture and that all of the carbonation (bubbles) help separate & lift the soil to the surface (vs. the use of soaps/surfactants) where it can be absorbed by the bonnet pad (better if used slightly damp).  Use both sides of pad per 100 sq ft, groom carpet...Hasta La Vista.
The newer system that's being used is the truck mounts.  They have 2...the CTS 450 & CTS 330 (difference is horse-power 16 vs. 24).  CTS stands for "Carbonated Truckmount System".  They still use the Natural, but it's called the "NATURAL IV" (they've changed/upgraded a few times).  Some of the older CTS's had small (5 gallon) tanks....3 5-gallon tanks for "A" solution, and 3-5-gallon tanks for "B" solution.  Sucked big time, only 30 gallons of cleaning solution, and with low psi 120.  They upgraded and found a way to use a single solution (Natural IV) and now most CTS's have 2 15-gallon tanks.  The solutions is heated and runs through a RX-20 knock-off called the "Power head"...it's identical to the RX-20, except the cleaning star has 5 jets and the amplified extraction (holes vs. slot) vacs.
The Home Depot purchased CD several years ago.  It is mandatory for ANY CD that gets a job through THD that the CTS is used, same goes for corporate jobs.  So, the benifit of a CD to upgrade (besides not being a f%*king hack) is more jobs.  The word was (before i left) that ALL Chem-Dry's would be forced to use HCE (Hot Carbonating Extraction...a lot like HWE huh) either with a Porty's (called the powerbase) or the CTS, and bonnet cleaning would only be acceptable on commercial grade carpet.
The fact is:  the CTS, even with sucky psi of 120 still cleans great....just slower.  The TM's are made by
Hydramaster.  The f%cked up thing is, CD started offering tile cleaning several years ago, but the TM's still only go up to 120psi, we had to use water-otters for pressure.
Just a lil' side info: the natural IV costs $6.00 per pack (makes 5 gallons).  So to fill up the 2 15-gallon tanks....30 gallons of cleaning solution....$36.00 a pop...that doesn't include pre-spray costs.  Imagine if you had to spend $36.00 each time you filled your tank 30 gallons...yikes!!
Hope that clears it up for you a little better.
P.S.  just looked at the title of your thread:  "HWE" and CD's "HCE" are the same thing...Chem-Dry is now apart of the "steam cleaning" society.  They still try to market CD advantages (low pressure/moisture, non-toxic, no residue etc...)  But bottom line, if you have a porty/TM w/ heat and RX-20, you can clean just as good.
