Does it even make sense to have a helper when using a Hydra Force Sprayer? Do you guys have two solution lines in the home so you do not have to stop? One for the wand and one for the Hydra Force?
Golden Boy
Golden Boy
No dwell time, Mikey?
Not too far i dont like it when the Pre-Spray dries up.
single wand, two man crew in res w/HF is about the most inefficient way one could do it
If you want to intelligently discredit a mans argument, find factual ways to counter it. Do not succumb to the foolish temptation to grasp at the most ridiculous conclusion an present it as fact.
empties under 1000sf can work...one man grabs the HF and sol line and heads for farthest point, while second man hooks up water, plugs in sol line and turns on pump.
the whole joint gets hosed down while vac hoses are being set up
H
Even if I have to stop the wand for 20 minutes(lol) while lugnut pre sprays it's still gotta be better than a pumper.
Unless you can run two solution lines.
