- Joined
- Oct 6, 2006
- Messages
- 117,284
The AWDS is an additional wastewater pumping/disposal system we are offering as an alternative to our Auto Pump Out (APO).
The best and fastest way to learn more about the AWDS is to watch this video from our truckmount product manager, Chris Ryan: . You can also learn more from the attached product information sheet.
The Automatic Wastewater Disposal System (AWDS) is designed with low torque bearings to allow for more flow rate than the competition, while drawing the same or fewer amps. Extra-large valves allow larger solids and debris to be passed without clogging the system. The kit has been prewired and preassembled, making the installation easier than other automatic pump-out systems.
Features of the AWDS pump include:
· 8 Gallons Per Minute flow rate
· Low Amp 1/6 HP Gear motor
· Extra Large Valves
· Sturdy Powder Coat Base
· Integrated wiring for easy install into any machine
While specifically designed to integrate with HydraMaster truckmounts, the AWDS system can be installed for use with virtually any brand of truckmount. The AWDS kit 000-079-220 is designed to wire into any system. There is no need to add additional circuits. The AWDS can be installed into any auxiliary switch. The plumbing allows for a floor installation in virtually any location with the supplied fittings. The pump requires 1.5 sq. ft. of clear floor space. THE AWDS is priced very competitively as compared to similar systems.
Regards,
R. Doyle Bloss
Marketing, Product, and Brand Manager
HydraMaster/U.S. Products Pro
11015 47th Ave W
Mukilteo, WA 98275
800-426-1301, x 1728
425-775-7272, x 1728
www.hydramaster.com
