Does anyone have one? Do they work? are they better than rotovac 360?
Jim Martin said:set the head up correctly and let the machine do the work for you and on those occasions that you need it ...it is a great cleaning tool and won't over wet the carpet....I personally found that if you RX into the room and then get your wand and cut everything in and dry stroke on the way out it leaves the carpets looking great.....
