sdaws4 said:
Wondering if you like you the 2inch Hydrofilter or is it to restrictive? I do a lot of 150-250 hose runs and don’t want to regret buying something else. I know that you have to buy the SS filter.
If you get one and it is set up correct then it will do you good.....
If you get it out of the box from Interlink then you are only getting half the puzzle...
when this was handed to Interlink...( and I still don't really understand why)...All they did was have someone drill out the filter and put the adapters on and throw one of those P O S socks in it and jacked up the price..
Ever since I designed this....I have yet to here of an complaint about any that keep coming apart ..But if they did it was because whom ever was drilling them out did not take the time to make sure it was centered properly..there is some forgiveness with the 2 inch....but you almost have to be on the gnats ass with the 2.5
If you do get one from interlink...throw away the sock and get the stainless basket..
drill some 1/2 inch holes in the bottom....
and then line it with a knee high nylon.....
the holes at the bottom will pull the nylon and all the crap to the bottom and leave the sides of the filter clear.....
when it gets full...just open it up and replace the nylon and keep going...you don't have to scrub nothing out.
