1,000 PSI Heavy Duty Ball Valve
$19.35 Value!
The Hydro-Force High Pressure Ball Valve is our highest pressure rated valve using the slim, lightweight profile that professionals love. This stainless steel ball valve uses high-strength, long lasting PTFE seals that will outlast standard brass valves when used at the high pressures required for tile cleaning. It's all stainless steel body construction also prevents splitting that can occur with cheaper brass valves.
The ¼" FP x ¼" MP thread design eliminates the need for additional adapter nipples. Simply thread one end into your male hose end and the other to your quick disconnect. A quarter turn of the knob is all that's needed to turn stop the flow of water.
1000's sold with excellent feed back and durability
90 day warranty.
ENTER HERE
$19.35 Value!
90 day warranty.
ENTER HERE
