bob vawter
Grassy Knoller
FIDDY-FI HUNNERT!
Odin said:just go and carve yourself out a new one
this is part of bob's genius non propriety design
that's the beauty of a Steam Genie...unless you've RUN ONE....Hoody said:The pulleys can be bought out of a Granger catalog.
hey Clayton....the unit you're looking has a low hr USED 47 blower and REBUILT hydra cell...all else is brand new...the one i sold last month WAS brand new...thus the higher price...i sold it for $7000.00! if you want a complete brand new EVERYTHING...the price is $7000.00sam miller said:I had an sgs 36 sizzler my first truckmount propane very hot got that over a blazer very good decision do you make these new Bob?
and did you work for Steam Genie back in the day?
whats the Blower size and heat at wand?
http://www.steamgenie.com/
205 ATM....of FREE...SAFE.....RELIABLE heat...vincent said:So, how hot does it get at the wand?
I believe its been asked several times now. !gotcha!
I've used all brands...the WM that you can see in CRASHES pic is a good one....gtech12v said:What type of heat exhangers are you using on this units ?
bob vawter said:what part of a Direct Drive would someone think you can't buy.....?
ANYTHING mechanical can be fixed.....if yor shaft is noisy i would suggest that you pull it apart and install new bearings.....rhino1 said:yeah Bob, where can we get a replacement shaft? Mines kinda noisy.
bob vawter said:ANYTHING mechanical can be fixed.....if yor shaft is noisy i would suggest that you pull it apart and install new bearings.....rhino1 said:yeah Bob, where can we get a replacement shaft? Mines kinda noisy.
If a bearing has RUINED the race that it rides on...you jus take it to you're friendly machine shop...have them turn the race down...THEN build up a collar and press on the end of the shaft....
i have about a DOZEN shafts in my shop...
