- Joined
- May 19, 2007
- Messages
- 4,055
Finished this floor on saturday. It's in a 100 yr old home the guy is fixing up.
TimP said:The place was horrendous before he started fixing it up. He's spent tons of money on it. My in-laws business sold and did all their flooring. I just did the original finishing of the vct. I took those pictures from the guy's facebook page, so I didn't take the pictures. I thought it looked good after it dried cause I didn't stick around for it to dry since it was 7:30 when I put the final coat on.
I suppose you are one of those who will waste his time buffing each coat also. If you buff before the first coat to close up the floor you will use less finish and it will dry faster.If you didn't burnish out the last coat it won't hold up as well.
I maintain almost all the floors I do. And I do buff between each coat, they will hold up better that way.
steve frasier said:[
Hard as nails isn't a repairable floor finish, if you scrub it you pretty much have to recoat the entire floor to get it to match even with a propane buffer, so if you want to do maintenance you need a different product were you can scrub and recoat the traffic lane than propane buff and have the floor look the same across the entire surface
Your do it your way and I'll do it mine. I know what works for me.
steve frasier said:no ,you can burnish it but you will need a propane machine for hard as nails
if you were to scrub a 100' by 100' room, after scrubbing you will see where the wear patterns are. If you were to wax only the wear areas then propane buff the whole floor, if you use a floor finish that is repairable then you would be able to tell where you recoated the floor. But if you put down hard as nails then after you propane buffed the floor you would see where you waxed the floor. It won't match up where a repairable floor finish will
Ryan, I bet you use I Shine don't you and probably don't have a propane buffer so how would you know
I could restart as the first coat was dry.
steve frasier said:I could restart as the first coat was dry.
best way to have to do it if you can
no pissing match here, I have a hammerhead, 2 21", a clark boost and a 20" nobles speed scrub. a lot of you guys throw money out the door in time and product, I just want to know why you do it
If a product comes out of the bottle milky white and a slight brown tinge how do you expect to get the best shine out of the floor with it?
I have used everything from Spartan from On and On to ProShine to I Shine, sorry but the stuff really doesn't compare in shine and is poor in repairability. If that stuff is like 22% solids they why do you need 5/6 coats? 4 coats should be plenty if you are doing maintenance.
steve frasier said:I maintain almost all the floors I do. And I do buff between each coat, they will hold up better that way.
no they don't, you have just have trained yourself to think that
never met a janitor that didn't think he did floors better then the other janitor
They look good Tim, nice and clean
