Ron Lippold
who makes light weight 175 with a tank and 17 in. my 175 is wiegted for stone and just to damn heavy for every job.
Carpet Cleaning Fool said:RX-20's are pretty bitchin too.
They're super versatile and can do everything a 175 can do and more.
Greenie said:If you get a lighter one, you might want to look at a 15" so you keep the Lbs per square inch ratio, the "weight" is half od the magic of a good rotary working quickly.
I am curious to see the new Mytee rotaries up close and personal, they have handle releases up high, very important if you ask me.
Mikey P said:Rx20's run at something like 80 rpms" data-source="they can't do every thing a 175 does. Go post pad w/ OP pads 2000 ft of glue down with yours and get back to us.[/quote: 2" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">http://www.hydramaster.com/accessories/rx20.asp[/url]
Here's a shot of my right hand man and a couple RX's on a 3500 s/f laminate job. The RX-20 is the most versitile peice of equipment i own. Can't say that about the 17" Powerflite 175 i got sitting in the garage. Unless you call target practice versitile (plan on taking it to the mesa and blowing it to hell). 8)
rick imby said:Greenie
I thought you were close enough to the ground that the adjuster would be closer at the bottom of the handle....
Rick
Ron Lippold said:larry she is like 130
Ron Lippold said:larry she is like 130 some shearing will be better than no shearing thank god for judson juice but i would scrub more if she was not so heavy
Ron Lippold said:l but i would scrub more if she was not so heavy
