juniorc82
I have a hf olympus porty. I want to add auto fill. Is there a setup I can get for that type of fresh water tank? I thought I saw one at cobbs but wasnt for sure.
Wyatt Earp said:Should be easy enough to do, we added it to a couple of our portables back when we use to use them a lot on commercial work.
Just periodically check and replace the rubber seat on the piston in the float tank assembly. Also check it before operation, bumping and jiggling around can loosen the float and other parts. You don't want to do WDR for free!
juniorc82 said:I have a hf olympus porty. I want to add auto fill. Is there a setup I can get for that type of fresh water tank? I thought I saw one at cobbs but wasnt for sure.
