This is possibly going to be a bit long.
First off, take a look at the outside of the building before you even walk in to do a quote. Look for things like clean landscape, and over all a well taken care of building. That will give you and idea or whether or not the people that own, or lease the building care about the maintenence of it.
There are a multitude of selling points you can use. Appearence is the obvious, and the second being health, followed by investment protection. Your job is to figure which one(s) of these reason is why they've called you. If you're working with a multi-level building, ask if you can get a copy of the floor plans from them.
ASK to walk through the building, with someone that is in charge or a person thats associated with the building maintainence is even better. Write a lot of notes on things that you notice. High traffic areas, soiling levels, coffee and water stains near drinking fountains and break/cafeteria areas. Ask them questions on what they're wanting to accomplish with the cleaning(s).
You're typically going to find buildings with cubicals in them. I measure the areas wall-to-wall and then deduct 30% from that to cover the amount of space the cubicals are going to cover. I also measure out the common areas that aren't inside the cubicals. If wouldn't hurt if you did a cubical and chair count too, those get dirty and need cleaning also.
Now you actually have enough information to make a professional judgement call on their cleaning needs. Then you start making suggestions based on what they're wanting to accomplish. Clean the common areas every 3 months, twice with encap twice with HWE, alternating cleaning methods each cleaning. Clean everything twice a year, and the common areas get hit with an encap or bonnet at a cleaning in between.
People love options, when you give them only one option its either going to be yes or no. If you give them several options then you have a stronger chance at them picking one of them rather than throwing your quote away.
I break my "contracts" down somewhat like this.
-3 month cleaning -
Square footage x .15 = $total per cleaning
- 6 month cleaning -
Square footage x .20 = $total per cleaning
- Annual Cleaning -
Square footage x .30 = $total per cleaning
You may have a totally different format like this:
- Custom Cleaning Package -
Common areas(5000 sq ft) x .15 = $total [To be cleaned every 3 months ]
Cubical areas (3000 sq ft) x .20 = $total [ To be cleaned every 6 months ]
Office chairs (150 count) x $7.00 [ To be cleaned annually ]
Total Annual cost = $$$$$$$$
Total to be billed MONTHLY = $$$$
I hope this helps some of you. This method is great for monthly residual income. It does have its risks, based on accounts not paying on time. Also for larger contracts, you may need to invest in some equipment(Cimex, Portables, Another TM & Van). I urge you to be cautious, I've watched a lot of people invest major money into these things only to lose the contact a few months down the road. You then have an investment that you have no revenue to pay it off and make money from. Don't bite more off than you can chew and don't always look at the $$$$$$. Start small, and grow into the bigger accounts if thats what you want to do. Or simply stay in smaller commercial - every bit of residual income you can obtain is going to save you behind in the slower winter months. If you're cleaning frequently; and alternating between encap/bonnet and HWE schedule the encap/bonnet cleanings in the WINTER. You'll thank yourself for not have to drag out the truckmount in the snow and cold.
