I was overdue
So this month I’ve made $110k on the market, yet I still leave the house to clean carpets.
Today was a reminder of where I started. Good times.
Of course I was 4 feet short on my hose and had to pull out an additional 50’.
That is always the story with residential! I don’t think I’ve ever had a job with just the right amount of hose.
  • Dislike
Reactions: Nomad74
icleancarpetz
Rafael Samson
View attachment 128931View attachment 128932View attachment 128933View attachment 128934
amazing….was thinking the other day of adding 5-10 ft just for this same situation.
Thanks for the reminder.
I use to use that set up 4 to the door thing or was it 2 to the door. Got tired of it. Never thought it increase was worth the extra set up.
Since doing a an overhaul on my tm and skilled welder to custom a few things, it’s increased airflow by about 20-30%. I can no longer use the Rotovac 360….so much air flow it nearly locks the rotovac metal vac boots to the carpet causing the motor to spin way way slow.
Change your armature on your rv360, I had the same problem.. It wears out over time.. I've ran 2.5" to the rv360i & xl, I push the limits..
Reactions: icleancarpetz
Jeff T
We carry a 25’ (shorty), and a 10’ (stubby) on the van at all times…
I use either one almost on a daily basis. It allows us to customize hose lengths with ease…
They also serve as dump hoses at the end of the day.
Is this not common practice in this industry?
icleancarpetz
Rafael Samson
Have a dump hose of about 7 ft.
Gotta add another 10ft just keep forgetting….one of them things that don’t come to mind until you need it.
Reactions: Nomad74
KevinD
Kevin Dumas
I had an assortment of hoses. 10' 15' 25'
Right after a 50' section of hose slid next to my propane heater.
