I'm Gutting Tomorrow
Willy P
Vancouver
Willy P
I'm pulling the Lambs and putting in Domels. I guess I'll guinea pig to see how well they hold up. Question for the vac gurus..... I'm going to 3 three stage motors - Keep them all in parallel? or 2 in series and the third on it's own stand pipe? Or all 3 in series? :shock: ?
Willy P
Vancouver
Willy P
Here's how they'll look:
P
pinnacle
I look forward to see your setup for the Domels. Three 3-stage should produce a good deal of lift and CFM.
P
pinnacle
I have a setup of 4 Domels.
My setup is of 2 Domels in series, then those 2 pair in parallel. Using Domel #49137523 3-Stage 131" Lift, 107 CFM.
My setup I get about max of 195" water lift and about max 214 CFM.
I'd suggest that if you want a long hose run of say 100' them put all your motors in parallel so you max out the CFM. But if you are running 50' or less of hose I suggest you try the 3 motors in series for a very strong lift.
Willy P
Vancouver
Willy P
Brian Luddy said:
Can you post some pics also?
I won't be there personally as I have to go get the staples removed from my gut and seeing my lawyer about a car accident. But, I'll see what I can do.
