I thought “well formulated “ was banned here?
Love using my Prochem All Fiber rinse. It's become a staple in my arsenal.
Clear water rinse does not remove as much residue as a proper extraction detergent. Put some on your hands and see how long it takes to rinse off under a tap.IMO an acid rinse is only needed if a high Ph pre-spray is used.
since I'm mostly cleaning wool, I clean at 8 ph.
However, when I had my V I might only do 2 strokes, now I'm doing at least 5 strokes.
The use of CWR vs Acid Rinse will depend on the pre-spray used and the detergent residue left by prior cleanings.
Don’t get jimmy startedI never got my sample that I requested.
Well let's back track mikey because you said you use a cwr with that nano prespray. That's what I do ...............still
I believe you.I keep hearing guys who insist on an acid rinse because they want to neutralize their high ph prespray but they have never performed a ph test on the carpet after cleaning. I can use a 10 ph prespray, rinse with 10 ph extraction detergent and still leave the carpet close to neutral. The reason we use a high ph prespray is because the soil in the carpet is acidic in nature. Try this test, take your favorite 12 ph prespray, scrub it in with a crb, let dwell for at least 10 minutes, then test with a ph indicator pen. Tell me what the ph is. Having said that, I don't go over 10 ph on residential unless its trashed. Products like Code Red or Prochem Extreme are for commercial. I rinse with Procyon Plus powder, ph around 9.5-10. My carpets are never browned out or crunchy.
Are you saying that you can rinse your prespray off your hands better with more cleaner?Clear water rinse does not remove as much residue as a proper extraction detergent. Put some on your hands and see how long it takes to rinse off under a tap.
If you dilute a extraction detergent to the correct amount and spray it on your hands, yes, it will remove the traffic lane cleaner better and faster.Are you saying that you can rinse your prespray off your hands better with more cleaner?
I feel it rinses best with hard water. I use soft.
When I use Ultra Pac I use a lot of it. I think a swr works best for that.
I use all fiber rinse when I'm using prozyme plus and OSR sometimes. Depends on if I soak it down or just treat some areas lighter than others.
I've seen products gel so ultra pac to me is stand alone. The gel has nothing to do with how well you flush it. It happens on contact and the way i soak em down i doubt I'm getting it all back out no matter how much I flush it. It doesn't rinse easily no matter what.
Try it, you'll like it and your hands will be clean for once.Ron you are brain washed from so called experts telling you so.
And just like all of the "experts" telling us about covid-19..................they are full of shit
Whats your dilution?Love using my Prochem All Fiber rinse. It's become a staple in my arsenal.
