Thanks to all those that chimed in on the initial post.  I have made contact with all 3 parties that may be responsible and will leave it to them to sort out the payment.  I was also able to get into the two upstairs units although I did not remove any drywall, there does not appear to be anything unusal going on up there.
My followup question is this. Is it possible for building material that has gotten wet to have (or at least show higher) moisture than surrounding materials even after it is dry?
OSB in the affected area reads 14%. With equipment running and focused on this area, I can get it down to 10%. OSB that never got wet reads at 8%. As soon as the dehu is turned off, the affected OSB goes back to 14%. Studs in this area read normal. We are only talking about 3 sq feet of OSB that got wet. No insulation between units. I'm just wondering if the to loss could have allowed a foreign material (maybe silica from tile/grout floor above) to soak into the OSB and forever change the moisture reading of this material. IR camera does not show a significant temperature difference between affect and unaffected areas.
Thanks!
Thanks!
