Industry Acronyms - Add to the List
Blue Monarch
Dirk Wingrove
This could help some of the new guys. Keep on topic or it goes byebye.
I'll start with one....
APO = Automatic Pump Out
Larry B
Larry Burrell
Bawb = bob vawter
:wink:
QC = Quick Connect
GH = GreenHorn
B&S = Bait & Switch
CC = Carpet Cleaner
Bob's new steam genie = old, used steam genie
WC = Water Claw
WD = Water Damage
Mrs. Piffleton = customer
M
Mark Imbesi
HWE = Hot Water Extraction
VLM = Very Low Moisture
ATW = At The Wand
Odin = Terry Brevik
CDS=Clutch Drive System Truck Mount
GG=GreenGlide
GGG=Genuine GreenGlide
GGCVTiW=GreenGlided Checkvalved Titanium Wand
GH=Greenhorn wand
BG=Before Glide
AG=After Glide
Disty=Distributor/Supplier
JJ=JudsonJuice
TM=Truck Mount
PF=Pool Filter
ILF=Inline Filter
AC=armor class
HP=hit points :lol:
John LaBarbera
Bob Foster said:
DAP=Dumb Ass Post
TAs = Traffic Areas
QC = Quick Connect
LR = Living Room
DR = Dining Room
BR = Bedroom
YP = Yellow Pages
KAD = Kool-Aid Drinker
175 = Rotary Machine running at 175 and also possibly higher if it's a dual speed
CRB = Counter Rotating Brush as in Sibo, Whittaker, Icapsol
OP = Oscillating Pad
Dehum = Dehumidifier
Snail = Snail shaped air mover
HF = Hydoforce
MF MikeFest
ATM = Temperature of Water at the Machine as it leaves going through a solution hose
ATW = Temperature of Water at the Wand
DP = Dew Point
RH = Relative Humidity
RTU = Ready To Use
WD = Water Damage
Wand Jet nomenclature
first three digits = degrees of spray last two digits= gallons of water per hour at 2000psi(?)
11003 = 110 degees 3 gpm
I think it's at 40 or 45 psi.
Great thread. I learn what I was afraid to ask.
Here's one
DSL dual splash lubrication
and one more
B.O.S.S. Battery operated solution sprayer.
Ron Lippold said:
hey john is the new sprayer ready yet the pump in the old new boss went out allready
How in the hell do you kill those pumps?
gotta be the solvent content?
FB7777
CFM ..... cubic feet/ minute
POG...... Portable only guy
BANE..... Barely Any Noticeable Extraction
Brian R
Brian Robison
And the fitting one
DAT
I didn't see that one posted.
John LaBarbera said:
f last two digits= gallons of water per hour at 2000psi(?)
[/quote]
it's "tenths" of a gal @ 40psi
IE; a 04 jet flows 4 tenths of a gal @ 40psi
Whether that equates to 4 GPM @ 4000psi, I donno
GPM = gallon per minute
chem pumps and flow meters are measured in GPH = gallon per hour
CWI = carpet wand interface (where the wand meets the rug)
