C
chervenc19
My heater on my Ninja 500 psi with heat as a small crack in it that causes it to leak. I purchased some JB Weld a while back to fix it and I am just now getting around to it. In the manual for the machine I don’t see any specs on the heater but online I think I saw it is an inline 1800 watt heater. JB Weld says it can handle 250 deg F continuous and 300 deg F intermittent. Does any one know how hot the outside of this heater will get and if the JB Weld will work without creating a fire hazard. I have been using the machine without heat just fine but would like to try and fix this. Also what type of insulation do I need to get to wrap this thing back up and install.
