steve g
I have been using my KMA parker paraflex hose for at least the last 3years, bascially whenever it first was sold. it has been my lead hose so its been used on every job. today I noticed a very tiny stream of spray coming out near the swedge fitting, I thought of pulling out another hose, however it was such a small stream I decided to just leave it and clean anyway as that part of the hose was outside, I finished the job and apparently when the hose gets hot the leak seals itself. so I ran some cool water through it to pin point the leak so I could have the hose re swedged. looking closely there are a bunch of tiny spots where the hose is sweating its evenly spaced like every inch of so, they are very tiny run the spot with your finger and the water goes away for a couple seconds then just slowly comes back. the hose does this for about 3 ft behind the fitting. anyone else seen this, is my hose ruined, do I need to lop off 3 ft, or will I start to see issues with the rest of the hose.
