juniorc82
I was thinking of getting a 2ht to add to a thrown togather electric tm to do some rentals with the summer. im trying to be cheap and save a buck or two wondering if the 2ht will cut the mustard
when its all said and done it will be 2 3stage vacs , one 2 stage vac ,and a 3 stage vacuum booster either ran from the van or inline . Auto pump out going to a 50 gal drum and a 50 gallon fresh water drum . it will be rigged up and nothing to write home about but I thought that with the propane heat and not needing to wheel in the porty it will help me increase my production for the time being until I can buy a nice used tm.Ryan said:There's less than a $100 difference and you almost double your btu's with a 3ht. I like too see some pics of your electric tm if you have it done. Dual three stage vacuums?
juniorc82 said:when its all said and done it will be 2 3stage vacs , one 2 stage vac ,and a 3 stage vacuum booster either ran from the van or inline . Auto pump out going to a 50 gal drum and a 50 gallon fresh water drum . it will be rigged up and nothing to write home about but I thought that with the propane heat and not needing to wheel in the porty it will help me increase my production for the time being until I can buy a nice used tm.Ryan said:There's less than a $100 difference and you almost double your btu's with a 3ht. I like too see some pics of your electric tm if you have it done. Dual three stage vacuums?
Nate The Great said:juniorc82 said:when its all said and done it will be 2 3stage vacs , one 2 stage vac ,and a 3 stage vacuum booster either ran from the van or inline . Auto pump out going to a 50 gal drum and a 50 gallon fresh water drum . it will be rigged up and nothing to write home about but I thought that with the propane heat and not needing to wheel in the porty it will help me increase my production for the time being until I can buy a nice used tm.Ryan said:There's less than a $100 difference and you almost double your btu's with a 3ht. I like too see some pics of your electric tm if you have it done. Dual three stage vacuums?
Would you be running the cords to the apt or using a generator? Is there something wrong with your Recoil? Seems like you have everything your thinking of doing in the Recoil. Why not just leave the Recoil in the van, run the hose to the 55 drum, auto pumpout, then run your inline booster? Add a little giant heater and your done.
dave105 said:I had a 2ht and then a 3ht hooked up to my cub xl and they both cranked out the heat. I would talk to greenie he walked me through setting them up to maximum heat settings, beyond what comes standard on the unit.
