Living The Dream
- Joined
- Oct 25, 2016
- Messages
- 3,218
- Name
- Swani
He said it worked when he last used it.is the wiring job warrantied?
It would be nice on commercial jobs. No stopping to dump.He said it worked when he last used it.
Looks like a $2000.00 unit,
If it's working, yes. The fitting where the pump out garden hose goes on should have a check valve. Needs to be lubricated with wd 40 or similar often. I have a couple of similar ones made out of plexi-glass.Is this pump out worth $200?
They should bring back the plexi-glass ones. People are absolutely amazed when they see how black the water is coming out of their carpets.That was once the only choice available for an automatic pump out.
I always found them easy to use and to maintain.
Good thing I don't live in California.Some things are better left unseen. The last thing I want is some type A home ow er coming up to me concerned about pumping dirty water into their schrubs.
I thought people would want the waste water with the drought? Nothing better for the shrubs then a little organic water.Some things are better left unseen. The last thing I want is some type A home owner coming up to me concerned about pumping dirty water into their schrubs.
Is that AC current power?
Its AC. It would be great for big jobs so you wouldn't need to shut down so much. You could use it on residential if you don't mind using the clients electricity.Is that AC current power?
if so, I'd rather plumb a sewage rated sump pump in the waste tank.
(I did just that on mine)
I find mine very useful on large jobs. Also acts as an inline filter. Customers have no problem with plugging into their power.Yeah, it's inline
i guess it adds additional capability like maybe on commercial or an in plant situation but I don't know how useful it would actually be elsewhere vs a pumpout in the truck
That's a great deal! Try it for a while, if you don't like it put it on Ebay for $500.00.I got it purchased tonight. $250 shipped. Thank you everyone for your input.
