http://www.flir.com/thermography/americas/us/view/?id=61255&collectionid=836&col=61440
I would like 2 please!
If you use a ticker (non-contact voltage detector) to verify a circuit is dead, find a live circuit like a receptacle and make sure the detector works. Then, without setting it down, putting it in your pocket, etc. immediately test your circuit. Do this every time. It's the only way to make reasonably sure the device is OK.
If you're just trying to make sure a circuit is live, then just use the ticker normally.
