Judson 02 PH Tests
C
Curtis Pennington
As a response on topic below I did some PH testing on JJ friday and here are my results.
Undiluted in the bottle PH 9.5
Diluted in HF recomended concentrate PH 9.5
Diluted in same HF added Hot sauce PH 12
Dont get any better than that, That covers it all far as strength in various cleaning situations. I have been testing some other liquid presprays and as you add your water they drop in ph as much-2 (example ph of 10 undiluted, then adding your water mix in HF drops to 8 )
So your not buying water From Judson....................
Hats off to Les for making a legit concentrate.
E
ErikG
Thanks for tid bit , is there any other company out there that sells concentrate to c/c or judson
