What about the waste tank issue Les mentioned? You have any issues there? Did you have to modify anything else? Do you have any pictures of this setup? I'm picking this machine up today but plan to up grade down the line. He said the Nitro with 33 can clean up to 200 residential and 300 commercial.
Don, I sold that machine some time ago. The issue Les would have mentioned is having too much air velocity at the blower intake, causing waste water to get sucked into the blower.
This was not an issue for me, I would say it would have been with a 45 or especially with a 47.
To fix this, Les gave the TNT's a MUCH bigger opening for the blowers intake connection. This reduces the Velocity.
The upgrade to the 36 was cake, I simple took the sliding plate it was on, Welded another plate to the back of it for the back legs to rest on, as the only difference between the 33 and the 36 is that it is 3" longer in the back. Front is exactly the same, shaft and all.
