Brian R
So instead of bringing the cruddy little vacuums into a customer's house like most cleaners do.
Why couldn't you have something like that in your van...smaller of course...that you could operate a dry vac in the home using the same 2' hose that you clean with?
Just have a tool that hooks up to the end of the hose for vacuuming. I know they have those that you can run off the TM but I've been told there is too much vacuum and they burn out.
And no one wants to use a $15,000 machine to vac with.
A smaller, electric unit in the van would be way better than bringing in an upright if not just for the noise level and pollution level of the indoor environment.
Not too mention, you wouldn't have to empty the dirt cup or change bags 10 times on each job like Werner does.
Someone HAD to of thought of this already, right?
