Larry B
Just wanted to drop a note about ABS systems so you don't make the mistake I did.
On Monday the ABS light came on in this Chevy van with a SG system that I just got. On Tuesday I had an appointment to have it checked out but I had a job in the mountains to do first thing so I decided I would use this van then just swing over to the shop (it's just a light right?).
The van has the large SG fresh tank in it so we don't have to use hard mountain water to clean so I filled it up and away I went. Got the job done and started down the mountain and found there was no brake pressure to stop the van. After a couple miles going down hill smoke started rolling out from under the van but was not able to get it stopped. I came up on a hairpin curve the van was only doing about 15 and things were looking good to just jump out and let the van go. (didn't do it)
When I got to the bottom of the mountain I was able to ride the ditch to get the van to stop and I'm still alive.
The van was taken to the shop and what was found was the front brakes and rotors were completely burned up on the van. The ABS sensors along with the plastic lug nut covers on the front end were burned off from the heat of riding the brake that far. The rear brakes were shot and the oil seals in the rear axle had melted down.
Point of all this: That ABS light was a warning that the system had a problem (Duh)
The ABS system for some reason thought the brakes were in lock-up and would not allow full pressure to be applied to the brakes so even with pumping the pedal the system would not kick off and allow the brakes to grab tight.
So if your light comes on and brakes feel a little sponge I would have it checked first.
