I have them on two of my TM's, but not to save $
Unless you keep a TM to about 9000 to 10,000 hrs, you won't save a nickel unless your time is free and you can get the cleaner and oil free.
And - don't drink the kool-aide - k&n's don't filter as good.
The reason I have k&n's on the 2 tm's is they are older carb'd tm's that have a lot of oil blowback, and paper elements end up with too much oil in them very quickly and start to restrict airflow after 300-400 hrs, the k&n's go 600 hrs before I have to clean them, and I do have a foam element around them.
If you ultimate goal is to keep your bottom end cleaner - stay oem manufacturer paper. Get a universal airbox vacuum sensor Ron suggested, and change it when the guage says it's time to. A brand new paper element vs a 75% used paper element that looks real dirty won't let any more dirt through, nor will it restrict airflow to a degree it will affect anything on an engine - the only thing you need to change an air filter for is airflow restriction, which the vacuum gauge will tell you by measure.
