Captain Morgan
I completely lost water pressure on my Steam Way 1150A a while ago. I finally save up the money to get it looked at by my mechanic.
Discovered my filter had a fair amount of scale in the filter. Tried to flush out the lines out with tons of black water, (the color of oil) would come out and then the line would clear.. over and over and then it finally was just clear.
He told me the kero fired burners have this problem and that flushing the line prior to beginning any cleaning is required.. understood, easy enough. That was Tuesday and I had my first cleaning since I got back from the shop. As my luck would have it... I flush the lines, have clear water, burner firing, all set to go with water temp set at 200 not wanting to push it. I start on the second bedroom and you guessed it.. no pressure. I run to the truck, grap a spare female QD and bucket. I couldn't get the line to completely clear... the water would be slighly rust/brownish or light grey colored with little salt sized black granuals then it would clear. I would get about 10-12 decent wand strokes and then water would stop... I think my jet is now plugged or the QD on my wand.
My question is.... is this something more serious than what I've been told it is? Are my pump seals or water pressure lines on my machine disintergrating or something? The previous owner only fresh water rinsed when he cleaned, nothing else so I was surprised to see so much scale in the filter. He was on flitered city water but would occassionally hook up to custy's water in out lying areas where there are areas with hard water. Also the machine sat for about a year without being run while I was working to save up the money for other repairs.
Anyone got any ideas what's going on? Should I descale the system or does my pump need rebuilding? My mechanic's helper was fidgiting with my pump. He was turning the inside section, (the belt spins/turns outside of it) and said it seemed loose... he said it shouldn't turn that easily.. and mentioned it might need a rebuild but was over-ruled by the owner/head mechanic. I'm in too deep with repairs to give up now and start over with a newer machine. I've got to ride this one as long as I can so I can make enough $$ to upgrade.
Any suggestions or assistance in troubleshooting this would be tremendous!!! Thanks in advance for your help. I tend to ramble... a lot so if you need me to clarify anything PM me and I'll respond directly or here so others can see what I've tried.
Thanks again,
Bill Morgan
Thanks again,
Bill Morgan
