TConway
- Joined
- Jan 18, 2013
- Messages
- 1,193
- Name
- Thomas Conway
Okay I want to say that most of you know Ken and this is no way to bash him but just a view of his idea.
Today I had a job that needed to be cleaned and dried as soon as possible. The carpet was a nylon fiber and was NOT very soiled so I started with a quick lay down of ps and started my cleaning I did the 3 upstairs rooms and landing. As soon as I was done with each room I opened window placed fan at each room as I finished, did the stairs. Vacuumed living room laid down ps and went to check how the carpet was drying the first bedroom was pretty close,close enough to pull the fan and bring it down stairs to start the drying process.
This is where it starts when I was done I had already placed the fan when I started my rinse but the carpet was still a ways away, I remembered Ken talking about his process of using the blower like a blow dryer to help dry the carpet so I why not give it a try so I ran some odo ban (my cheap deo) down the hose after sucking some clean water to help rinse the inside of the hose, ( You would really need a true dryer hose to be used if this were to work)
On my TM I have my tank to blower set up for fast disconnect with 2.5 cuffs my blower is 2.5 x 2.5 intake/exhaust so I took them apart so my blower could pull fresh dry air.Hooked/slipped my starter 2.5 hose female over my blower exhaust set temp to high to keep my motor exhaust from being diverted out with blower exhaust so ONLY FRESH air could be blown back into house.
DOES IT WORK????
I would have to say YES it does the amount of air coming out of my wand (EVO 16) was enough to almost make it float I had to hold it down to the carpet like a air hockey table. It did seem to dry the carpet very well.....
BUT you have no idea how much shiznit is in a wand till you reverse the air flow HOLY CRAP I now know how to clean out a wand!!!!
Also the amount air was enough to blow deep embedded sand and hair out of the carpet with enough force that I could feel it hitting my legs. very noticeable in higher traffic areas and by the front door. This is the crazy thing I did 2 TWO passes over the carpet and not real fast as I was wanting it to dry but what I noticed was as it was drying it was making the room VERY dusty no joke there was hair and lint shiznit that blew out of the carpet and stuck to the walls,so much came out of the carpet that I did a dry vac pass to suck up all the loose sand and ?? what ever else came out of the carpet.
Now some of this may have been prevented with a good prevac but it had already bee done by the cleaners before I got there so I didn't prevac.
Ken's idea may have some merit and I can see his idea working but it would really need some way of keeping the dust down because as you dry the carpet the pet dander and just plain fine particulate really start to become airborne and No customer would be happy with that.
The best way I can explain it is like the videos of the guys using air to blast dirt out of rugs on the net if you have seen them you know what I'm talking about they are covered in a cloud of dust and by no means was it even close to that it still made a lot more dust than I would have thought would be possible. It was a lot of air blowing and it may have just stirred up the air in the room IDK.
Just thought I would share my boring day cleaning this was the last job of the day so I thought I would play a little and experiment a bit. I can say it really did dry the carpet though.
DOES IT WORK????
