knocking kohler
Louis
Louis
came outside to check on the truck mount and it wa came outside to check on the truck mount and it was knocking shut it dow the land hog was the land hog was clogged and the waste t and the waste tank was almost full fired it back up and no knocking
I came out and check the I came out and check the truck mount and it was knocking again shut it down let it cool first shut it down let it cool fired it back up no knocking ran for about 25 minutes and still no knocking
Came home and changed the oil to Valvoline 10-30
and is a sound like I'm heading and is a sound like I'm heading for a valve job
Thank you
bob vawter
Grassy Knoller
bob vawter
i betcha a lawn mower shop could hep ya out wit that.................again!​
SMRBAP
Anthony
I hate when my land hog clogs....... especially twice in the same sentence.
Thursday evening fun - try reading that second paragraph to yourself in a foghorn leghorn voice :)
SMRBAP
Anthony
We figured as much - lol.
What was the land hog supposed to be?
Shane T
Shane Tiegs
My bet is the valve lifters. Use a long screwdriver, put the end of the handle against your ear and touch the business end to different locations on each cylinder head. The banging is going to more noticeable in one location than other.
Louis
Louis
Ok lets try this again. My new droid update screwed up my phone.
I was on a job and the tm had been running about 3 hours. Went outside and the kohler was making a knocking sound. The Lint Hog was full and the waste tank was near full. Shut it down cleaned filters empty tank ck oil. It was in the middle so gave it a little oil. Finished the job and no knocking. This morning no knocking for 2 small jobs. On the 3rd jod it starts knocking at the end of the job. shut it down wrap up the job then started it again and no knocking.
Came home and changed the oil to valvoline 10-30 it had lucus in it. The stuff was like water at 38 hours.
So do the valves go out on these often ?
How often do you change your oil? I know a guy in town that changes his oil every Friday. He has over 6000 hours on his motor
It is a 22hp 1 to 1 with 45 blower
Thank You.
lint hog would be my guess
Yeah, a good lawn mower shop will get you set up. 1/2 the price of an autoshop
been changing mine every 50 with the oil filter, change the plugs every couple hundred with airfilter
Ron K
Shane, 1/2 Dowel will work and it's safer in case he uses the wrong end and slip's and then will always text like that!
Louis
Louis
Changed the oil to valvoline 10-30. did 3 jobs today machine ran for about 4 hours total and no knocking. Maybe lucus oil sucks for small engines.
I will keep you posted if it comes back.
a guy told me a while back that the smaller engines don't have the large clearances that the big blocks do, so they need finer oil to circulate.
Louis
Louis
Well #2 cylinder head was cracked and #1 was about to go on the head gasket. One bad lifter and the cam shaft is worn. I think I will get a new short block next year.
A friend is looking at Subaru engines rather than Kohler. The guy that deals with them says they are a better engine. I didn't even know Subaru made a small engine like that.
lucas foams up and doesnt circulate properly by itself. maybe not foams up but becomes aerated. you also should use straight 30 weight, 10 w 30 has detergents that break down and can foam up also. use a non detergent oil anyway whatever wieght you use. talk to your mechanic about it.
Louis
Louis
So the knock came back after 15 hours. Ordered new lifters and camshaft. Another cleaner said to use 20-40 oil until I get the parts put in. I went with 10-40 because it has been freezing here and that thick of oil with a plastic oil gear concerns me.
How thick of oil can you run in a kohler.
i dont know about your motor but ive ran straight 50 weight in motors that knock and smoke.they are already junk though. i was told to use 90 weight gear oil but was afraid. like i said do what your mechanic says, i havent messed with these issues in 20 years.
Shane T
Shane Tiegs
Don't bother with the camshaft. Have you decided which lifters are knocking? Just put the lifters in and try it that way. The lifters are relatively cheap and easy to replace. I'll bet there's nothing wrong with the cam.
a TM engine is never below 30 degrees
Forget all that oil additives and wonder oils
Buy Valvoline 10-40 and run it year round .
Ron, the Subaru is just another Chinese import
Louis
Louis
When we put the new heads on we seen that the cam shaft was worn. Another cleaner had the same problem and put in new lifters and they went bad in 2 days. He ran the 20-50 to stop the knock until he replaced the motor.
I was told to use a little thinner oil so it has a chance to circulate and lube things, 10weight or 5wt for sure.
40 wt would be the max I would use.
Louis
Louis
Well the cam shaft was wasted. Big flat spots on it. New camshaft and lifters on Sunday and was back in service on Tuesday. Runs nice now.
Shane T
Shane Tiegs
Good to hear it running well again. How many hours are on your 22 Kohler?
Louis
Louis
I have only put 87 hr on it. It was a used steamway when I bought it and the tach had a dead battery so I have no clue. It ran fine when I got it and in 50hrs it went to crap.
