Louis
So I have a 22 hp Kohler that had a leak around the oil breather gasket. Now it has a huge leak. I put new kit on and was told not to put any sealer on the gasket because its on the gasket.
Started up the motor and oil started leaking I went to make sure all bolts were tight and one stripped ( crap).
So I guess the question I have is when I take it apart again and fix the stripped bolt should seal the crap out of it or do I need A new gasket. Where did I go wrong, besides the the bolt.
Thank You
Thank You
