Aaabrightfloor
I am looking for a hot water pressure washer
what will you recommend?
where to buy?
thanks
where to buy?
thanks
Depends on what your cleaning due the high heat. Iv,e cleaned exterior of mobile home for the past 25 years and use chemicals over the heat. I seen some of the guys use both types abd return to the chemical method.
If you are looking to clean restaurants then I would again suggest you look at a Sanitech. Max temp. 300° Melts grease on contact. This machine was designed for kitchens and food processors. The Mark III is 1000 psi and the Mark IV is 1500 psi. 2.2 gpm 110v Propane fired. Safe to use indoors. Check out www.sanitech.com
