I would like to see a larger filter box, better heat wrap on the exhaust, and some way to change the oil on the water pump. Also would be nice to have some type of access door to the waste tank.
Nothing will phase the Cobster. Excellent Job Larry and the machine looks good.
Though looking at the way he operates the wand, he may want to come for a ride along with Mike or one of his glorified assistants.
Or maybe that hippie- not so Carzy Ray
I like he big boy power plant and it's not a huge deal but for a company like ours I'd want to be able to run the unit without incoming water.
Lots of times when doing wdr work the water is off due to the break and there is no access to water. Now if you carry your own you wouldn't have that problem but I wonder if the length of time extracting could cause you some heating problems. Most wdr jobs we do are in the 2-hour range but larger ones can easily be 5-hours.
LOL! Keefer I am one of them old Texas hippies. Now days though I don't have to tuck my hair under my hat. Doc the motor sits on top of the on board water tank. It just takes a quick switch of a couple of hoses and you can run extraction only as long as you need to.
I have the 2045 unit didn,t need the big boy unit. This month it,s 3 years old and has ZERO down time. The ease of the layout is great and simple. I purchased it because of Mikey,s board. I had enough with Hydramaster and a few others . I like slide inns. i find talking to Larry is a lot easier than some of the reps from the other companys. I also use Cobb,s chems on all of my jobs. Thank you Mikey & Larry. jz.
