George is right, it won't make much of a difference in day to day residential cleaning.
Now, that said....there is always a thing or two to consider
What some newbies might not understand, is only 1/2 of the question is being posed here. As usual the devil is in the details.
On Single wand with an avg. blower making 300+ cfm, it doesn't much matter if you have two 2" hoses feeding a single 2.5" hose or two 2.5" hoses, because BOTH offer decreased resistance to the avail. airflow in transit.
But here is the kicker.
Both are being CHOKED by a single 2" wand, and single 2" lead hose. So we have a "diminished returns" in effect here. So there is potentially only so much gain, we could couple 4 hoses to a super manifold, and again if it's a single 50' length of 2" feeding a wand as a Lead hose, there is the bottle neck within the system.
Although it is true that taking a given volume of water within an airstream and splitting it into two airstreams of the same area, the % of liquid to air is reduced in each stream therefore making the net airflow more efficient and helping to clear the single hose more efficiently, the same "could" be accomplished with a single larger diameter hose.
If anything, using two lines and TWO filters will have a positive effect because you are splitting your filtration and filter holding capacity, and just the sheer fact that 2 filters with twice the filter area perform better 1/2 full than 1 filter at 100% of capacity.
So no, 2 - 2.5" hoses are not warranted for most guys. But two 2" hoses and high filters may be.
