I have it set up so the wind doesnt blow out the pilot light.
Jim Morrison said:I have it set up so the wind doesnt blow out the pilot light.
Brent,
Can wind be a problem? I was thinking of getting the propane cart model that would ride in the back of the van but be pulled out and set beside the van while in use.
lance said:Jim, yes the wind can be a problem sometimes. I have a 2ht on a dolly with pneumatic wheels so I can move it around. I put some 2 x 4 around the bottom to deflect the wind.
If you're going to move the heater, move it as far as possible up the sloution line so you minimize the cooling of the water. I think it would work better that way especially when doing long hose runs. The cart you mentioned is a little bulky and not really made to go in and out of a van. You can get a dolly with big tires and cut down the handle and then bolt it back on. That way the dolly is just a little taller than the heater.
If you do get the 3ht make sure it has the high pressure coil in it.
Jim Morrison said:I would only use it for restaurants and super grungy jobs.
