bonesheal said:
If I set my
Butler reel up with a 2.5" hose attached to the live connection, would that be a waste of effort? With the 2" connection on the reel, I'm afraid the airflow would be affected too much to benefit.
Doesn't
Butler still have 2.5 coming off the tank to your hose reel...?
What we did..was cut a 6ft. piece of 2.5 hose & attach one end to the Waste tank...
Run the 6ft. to the side door..."between" the solutition reel & the hose reel."on the floor"..
Then attatch a 2.5 "cool cuff"...then pull off as much 2.5 hose as you need...and attach
to the "jumper hose" from the tank..!!! WE..always ran 50ft of 2.5..with a 50ft 2.0 hose
as a whip hose permantly attached as our leed hose.. :idea:
WE.also kept a 25 ft peice of 2.5 hose hanging in the back.. :wink:
MOST of our runs were less than 125 ft.. "the 25fter..mad it easy to set-up & break down.
