Lookie who won the FREE Hrydrovitalize tile cleaner!
SamIam (Ticket #2020), mirf (Ticket #2052) both will be sent a free gallon of Premium Acid tile and stone cleaner from Hydramaster
HydraVitalize™ is an acid stone, tile, and grout revitalizing and renewing cleaning solution. HydraVitalize™ is used to renew and restore stone, tile and grout that has not responded effectively to other types of cleaning, or that has been exposed to a build-up of hard water spots and deposits, grout haze, soap scum, pet urine deposits, rust, and efflorescence. The acid cleaning action revitalizes and renews the appearance of ceramic, porcelain and quarry tile, as well as grout, granite, slate and sandstone. It uses a safer and milder proprietary acid than conventional acids like phosphoric and muriatic so it emits fewer vapors and requires fewer precautions. It breaks down and removes scale and soap scum, removes the white haze caused by efflorescence and removes the oxidized and imbedded soil from porous grout, brightening and renewing the surface of the grout. This acid-based cleaner will etch or damage most marble, limestone and travertine surfaces, so only use on recommended surfaces and always pre-test in an inconspicuous area first.
KevinL
Kevin Leach
That's what the manufacturer says. Have you tried it?
Wooohooo!
Ill let you know how I like it
