Hello,
I have a problem with my Prochem apex truckmount. I have a loss of heat. The strange thing is is the truck mount heats up to 230 degrees but once I turn on or increase the PSI, I lose all heat.
The Prochem from 2004 and is not the GTX. I have thirty nine hundred hours on it. I have checked the filters checked the water box to ensure no blockage on the intake filters and the temperature relief valve doesn't seem to be stuck open.
The 2 blue hoses thin ones run to the waste tank. The one closest to the driver side runs to the water box which I assume is to the temperature relief valve. This hose or the hose fitting attached to the waste tank does not get hot. Conversely the other fitting which runs to the pump is scorching hot. Anybody have any ideas of what it could be any help would be greatly appreciated thank you.
kindest regards,
Ed
kindest regards,
Ed
