Got a new email, looks like an interesting combination.
Looking For A Chemical That Does It All (And We Mean All) And Saves You Money? Look No Further!
Groom Solutions, the industry's newest complete line of carpet and upholstery cleaning solutions, is pleased to announce the introduction of their revolutionary 5 in 1 Low Moisture Carpet Cleaning Solution - Peroxicap.
Peroxicap is a 5 in 1 multi purpose hydrogen peroxide activated and encapsulating polymer fortified carpet cleaning agent. It combines a synergistic hydrogen peroxide detergent blend with a special encapsulating polymer. The special peroxide blend oxygenates and activates the cleaning power of the polymers and surfactants, and also helps effectively remove many spills and spots (coffee, wine, blood, urine caused discoloration, and more) during the cleaning process. The encapsulating polymer bonds to, surrounds, and encapsulates soil. This encapsulated residue that is left in the carpet following cleaning can be extracted from the carpet during the routine post-cleaning and/or vacuuming process.
The encapsulating polymers in Peroxicap also assists the carpet after cleaning at fighting against re-soiling. Carpets cleaned with encapsulating polymers have been demonstrated to stay cleaner longer than when traditional cleaning solutions are used.
Peroxicap can be used effectively as;
*A hot water extraction prespray.
*A low moisture encapsulation cleaner.
*A bonnet cleaning solution.
*An encapsulating hot water extraction rinse.
*As a carpet spotting agent.
Due to the fact that much of its cleaning effectiveness is created by the peroxide activation and encapsulating polymers, Peroxicap does not need to use harsh solvents and high pH phosphates, making it safe and effective to use on all synthetic carpets as well as wool carpets.
