Curtis Pennington
- Joined
- Jul 12, 2008
- Messages
- 1,537
Why do some people install them inside there van?......what the advantages outside?(besides leak protection)....I have one LP (mounted underneath) outta 6, so educate my virgin LP ass.
Bone Collector said:Why do some people install them inside there van?......what the advantages outside?(besides leak protection)....I have one LP (mounted underneath) outta 6, so educate my virgin LP ass.
were they carpet cleaning vans Shawn..or perhaps a from collision?I've seen plenty of vehicles go up in flames, with plain old gasoline being the only fuel involved.
OK Shawn... lets look at faulty fuel taps......Shawn Forsythe said:When you look for one thing, I'm sure you can find it.
bob vawter said:OK Shawn... lets look at faulty fuel taps......
would you consider THAT a potential problem for slide ins....... ?
When i hear people talk about how they do it........
sometimes i jus cringe...
let alone the propane bottles i see bungee strapped to the trailers....
i know...i'm pissin' in the wind!
is it an unattended fire??dgardner said:So, what about these cart systems? How is one supposed to safely transport one in a van?
Of course it is assumed you roll it outside the van to use...
bob vawter said:is it an unattended fire??dgardner said:So, what about these cart systems? How is one supposed to safely transport one in a van?
'cides THAT LOOKS lik abomb!!!
we're gona BOLT it to the gooseneck hitch in the truck......bolted down tight...dgardner said:bob vawter said:is it an unattended fire??dgardner said:So, what about these cart systems? How is one supposed to safely transport one in a van?
Well, here is another cart-mounted hot water generator that is even worse. While the one I showed just burns quietly, this one actually mixes fire and gasoline to produce several explosions per second! And the owner was last seen looking for a forklift so he could transport it in the back of his truck no less! Can you imagine the mayhem if it were to tip over in transit?
6]http://www.youtube.com/watch?v=q55FqNICZpc6]
bob vawter said:you WANT that motor....don't ya?
Shawn Forsythe said:That setup looks designed for portable use insofar as porting it within the work area, and not necessarily for "on the road" portability.
If you don't want to transport the portable tank safely, then you shouldn't do it at all. You'd be giving Bawb ammunition for his doomsday scenarios. :roll:
i'll leave you wit THIS imagedgardner said:Or I could crank your super Paraplate regulator to the max and that great Wanner pump will pop the hoses and scald everyone in the room to death... That's kinda a problem everyone faces.
But enough! I cower before your superior intellect, knowledge and reasoning ability. You win. :roll:
I'm going outside to practice a little TIG welding before bedtime.
