Lubing blower
Since Keith is not responding right now, I will say wd 40. You are not lubing the blower. You are merely displacing the moisture that may have accumulated on the blower lobes. You only need a short burst, then let the blower run a few minutes to burn it off. Too much wd 40 or other spray lube may damage your blower in Keiths (able one) opinion and I agree with him. Your blower is lubed by the oil in the crankcase, not by spraylube.
Bc
Jeff T
Use LPS, TKX.... wd 40 is garbage. DO YOU WANT TO RISK YOUR LIVELY HOOD ON SOMETHING YOU CAN BUY AT A CORNER STORE?
Bc
Jeff T
The WD stands for water displacement. Been around for years and works great.
Actually Ron, if anyone does a search on it, it was invented as a solvent, NOT a lubricant. My TM guy, says, ‘NEVER use wd-40...’ he’s got 28 years, rebuilding TM’s... the product I suggested is DESIGNED for industrial lubricant/water displacing..... I have seen pics, and heard stories.... he, and another VERY well known west coast TM guy suggested I use this product.( Darnell from DK, Chris L. Both from Van.). Oh, AND, Cleanco suggested I use this product as well in the manual.....
Reactions: Lee Stockwell
Oh look it does mean water displacement
I like what Ron said don’t over use it!
I’ve never lost a blower on two 405 and wd40 on both.
Over 16 k hours and both are still spinning hahahaha.
Bc
Jeff T
I worked in heavy construction for 18 years. WE NEVER USED WD-40..... believe what you guys want, I will use the professional stuff, you guys use what you want.
Bc
Jeff T
Oh, really? Hmmmm...
Can anyone say ‘SOLVENT’.... answer me this, if a guy does a search, can one not also use WD-40 as a product TO DISOLVE CERTAIN STAINS/OFFENSIVE MATTER FROM CARPETS?..... eg. play doh, etc...... ( of course, no one here has ever used, or heard of this method)????? SOLVENT......
could be, I'm not an engineer. I have used wd40 for years and never had a blower fail. Too much of any spray lube apparently can get into the bearings and displace the grease and cause premature failure. Just repeating what I've been told but seems to make sense to me.
I'll spray mine in the middle of a job for extra vacuum. I use a lubricating oil and sometimes a lot of it.
You have to have a solvent to displace water.
Benton KY USA
Much ado about nothing.
You can spray chocolate milk, PBR or other urine substitutes with virtually the same results.
Then chase with clean warm water and allow to run for 5 minutes to dry completely.
Blowers don't fail from "unlubricated" lobes.
Blowers DO FAIL from lack of oil in the gearbox, ungreased bearings, solids and trash ingested thru the vacuum inlet, overheating from vac relief blockage, and blockage downstream of the blower. Excessive side load and similar installation error kill a few.
Georgia
This is what my rep from a truckmount department of a corporation told me
“Spray wd40 in it for 3-5seconds when the tm is at full throttle under load (vac hose blocked). Leave it that way for 20seconds to burn out the wd40. Unplug the vac hose, turn down throttle for 2min to cool down the machine and turn it off”
Do this at the end of every day the tm is used.
Lubricating while it's running reduces heat and friction allowing it to spin faster with the same HP.
