The Triple Strength High Foam Snake Oil is primarily for low moisture cleaning. It is the most concentrated formula available that I am aware of. Due to the level of foaming surfactant it may cause a slight issue with foam decreasing your vacuum. That said, Snake Oil (TS High Foam) is great for VLM & a decent deodorizer/odor nuetralizer too.
The Double Strenght Low Foam Snake Oil is also primarily for Low Moisture but can also be used as an HWE prespray. Although the surfactant content is lower, the amount of deodorizer is increased. So if you're doing an asssisted living center & someones Depends leaked and you need to treat a granny pee spot.... The Snake Oil (DS Low Foam) is a good choice, especially if you want to extract or subsurface extract. Think of if as a stonger "encap
punch" type of product with a built in deodorizer, higher polymer & solvent content that works magic at 3-4 oz per gallon for VLM and 4-6 for HWE.
Anyway, the label on the low foam product will soon be changing. The best thing about this product is also it's achillies heel: Polymer & A LOT of it. There is a relation ship between how much soil can be encapsulated & how much polymer is present. Both versions of Snake Oil are loaded with it. Unfortunately, the Low Foam version (currently labeled with rinse agent instructions) tends to gum up the QDs & check valve strainers when you run it through the wand @ high heat. So emulsifier rinse/stock solution instructions will be removed from the side of the jug...
The good news is it took 4 months of daily use for it to become appearant. None the less a label change will be forthcoming this week. (I know this because I did & will re-do the label design & a fair amount of the Beta testing for Les.) Anyway, I'm still pretty pumped about the Snake Venom. I think you guys will love it once Les is done tweaking it.
