Ed Valentine
Although I am a newbie on this great board I also am recognizing that a large majority of participants are pretty experienced and knowledgeable individuals. However, my comments below are directed toward those who are not:
I get asked this question every now and then. So, here's the real truth without the sugar-coating:
Why do we not suggest the Operator securing their solution hoses to their vacuum hoses?
First reason, in regards to our equipment, it definitely would not make sense, period.
Second reason, the vacuum hoses will compress (shorten) somewhat under extreme vacuum performance and will thereby displace the match-up (position) between both hoses (the particular strapping material used). Therefore, one will end up "shorter" than the other. Further, the psi hose will tend to "twist" around the vacuum hose as well.
Third reason, it makes the hoses a lot heavier when hauling them in and out.
Fourth reason; In cold winter areas, if psi hose freezes, the operator has to submerge both hoses in a hot bathtub! What a mess.
Unless the Operators hoses are 10-15, my advice is to forget it because it is not faster and easier; rather a big hassle instead.
Hopefully some great advice from a "very" experienced former operator!
Ed Valentine
cross-American.com
Ed Valentine
cross-American.com
