Early 90's...Mannington had a product know as "Mannington GOLD"....very pricey...!
Over 50.00 a sq. yard then... :shock: It had a NO question's ask policy for 90 day's.. :!:
Almost ALL sheet vinyl goods were "NO WAX"... :idea:
"I would NOT use floor srtipper...!!!!!!!!!!!!!!!!!"
Most of these products have a urethane finish....Stripper will DAMAGE...
I would use your high alkaline pre spray...as a TEST...! It was NOT uncommon for
homeowners to apply WAX to no-wax floors... :roll: Especially if they had purchased
the home AFTER the vinyl was installed...! Many of these goods had a Matt finish.. :idea:
The NEW homeowner may have had a personal preference..for HIGH GLOSS finish... :|
Thus they would apply wax...! SO, actually the vinyl could be in great shape...because
the wax has protected the original finish from wear... :shock:
Have the CUSTY..sign-off... :idea: This will allow you to TEST an area & get a good idea
of what to charge.! Give it a go..!!! "You could be a HERO..!" and you have ZERO liability..!
Spray down a small area & scrub with a hand brush...Should tell you what you need to KNOW.!
