gimmeagig
I have been using At Last for a couple of weeks and I think I like it.
On a pee odor and stain job I have been using OSR before I switched over. I was under the impression that since OSR is an oxidizer I should water claw it out after 20 min or so but not rinse ore clean the carpets in that area. Is that right?
At Last is an oxidizer also but it's liquid and can be sprayed with a hydroforce. Beats having top mix OSR up in a bucket. Masterblend says to clean the carpets after using it. So why is At Last different?
Second question is mix ratio related
At Last is supposed to be mixed at 1:10 ratio. They say to use a 1:10 tip in a Hydroforce sprayer.
My Hydroforce is 1:8 it's the only tip I have and I don't want to change tips on a job. So that would make the solution a little stronger.Are ther any downsides or is 1:8 close enough?
