Metering Ratio
Anybody knows how to calculate the dilution ratio when you set the meter at say 2gpm or 4 gpm etc.
In other words in how many units of water is 1 unit of rinse (or detergent) coming out of the 5 gallon concentrate jug, being mixed with?
Thanks for your help.
Ofer
bob vawter
Grassy Knoller
bob vawter
My Dywers is calulated at GPH not per min.......so for example you had it set at 10 GPH then you could figure out the dilution ratio at 10%...
that MAY have not made any sense to most of you....!
J Scott W
Jeffrey Scott Warrington
Meters and machines will vary. Many products are mixed at 1 qt in a 5 gallon stock tank. This solution is then metered at 2 or 3 gallons per hour.
In practice this works out to somewhere between 1 - 320 to 1 - 500 depending on where you set the meter and other particulars of your own machine.
Scott Warrington
B&BGaryC
B&BGaryC
I usually meter at 4-6 gallons per hour. No wick-backs though. (ENDZONE Rocks. You can make it a monster with 8 oz of ENCAPUGUARD)
P.S. Scott: Tell them you're not paying me to say this. I just like Bridgepoint.
