Mounting a belly tank
vincent
O'Fallon, MO
Vincent Sapp
Trying to mount my belly tank for the lg.
The only clear place is on the driver's side just in front of the gas filler neck.
I have 2 "L" brackets, but the way the tank is supposed to go with the brackets, does the top of the bracket mount to the underside floor of the van?
I know this is simple but I cannot figure this out. No matter what you do with the brackets, it doesn't come anywhere close to bolting to the frame.
Need Some Help!!!!!!!!!!!!!!!!!!!!!
Scott Rogers
yes, mine is mounted to the floor.
Be sure to use large washers or backing plates to disperse the load.
saxman
Get four 1/2 inch threaded rods, large washers and self locking nuts. Drill up threw the floor, mount bolts, measure and make sure it will fit your bracket.
I had to cut into bottom of truck body to get it high enough, Ford 250. It was a bitch. Good Luck, you can do it.
John
You can call me if you have any questions, 815-389-3588
vincent
O'Fallon, MO
Vincent Sapp
Go back to the diaper pail Vawter
At this board, cleaners help cleaners, great ideas for the successful business owner.
As always, you add nothing to a conversation.
"As always, you add nothing to a conversation"
ROFL :lol:
I'm still waiting for Bawb to pull his weight and enlighten the youngins' before he takes all his secrets to his shallow grave.
Dallas, Texas USA
Vincent;
The short side of the "L" mounts to the floor of the van.
If the "L" is too short, you have to use longer brackets or space the "L" down with large diameter fender washers if it is close.
vincent
O'Fallon, MO
Vincent Sapp
Thanks Larry I was waiting for your response.
Probably like me, crying over that late FG in Washington.
Yes those brackets will work you sent me.
Thanks for rectifying the problem this past week and now the mounting question.
Dallas, Texas USA
Vincent;
Yes, I thought the Cowboys played fairly well.
Blocked easy field goal leading to an opposing field goal on a penalty with 0 seconds left.
That's a tough way to lose.
Larry
