MR KNOWITALL?
bob vawter
Grassy Knoller
bob vawter
Steven, i don't have a manual for a SG Direct Drive...however there are a couple people that MAY.....if you PM your phone # maybe i can put you in touch wit them......
Have you tried MR KNOWITALL yet?
If you have a specific question, i could prolly help ya!
bob vawter
Grassy Knoller
bob vawter
The correct angle is determined by the piece of angle iron on the main unit...your driveshaft should lay in that piece..Ford...chevy...Dodge all have the same engine tilt.....secure your front bracket, then line up your clutch to your belt system up front, tighten then move the machine accordingly.
bob vawter
Grassy Knoller
bob vawter
I always install 5/8 marine plywood ......theres a lot of wiggle room!
M
Matt King
I can copy you whatever you need from a manual. If it's going back into the same van it came out of you will be ok. Just keep the frame at the same height as before...
I'm curious ... by "Mr. Know-it-all" ... are you referring to Lee Stockwell, Shawn Foresythe, Mike Paytoilet, Tony Wheelwright, Dave Rampage, Fon Johnson, Jim Martin, or are you referring to one of our many BB huxters that frequent this board?
You need to be a little more specific, you old codger.
bob vawter
Grassy Knoller
bob vawter
There can only be ONE true MR KNOWITALINTHEWHOLEWIDEWHOLDANDELSEWHEREANDTHENSOME......
He needs no introduction!
